14 years agoHOW TO INTERFACE BETWEEN ETHERNET(CYCLONE III) AND PCs(Labtop)
Hi everybody!!! I'm studying with a topics "Interface between Ethernet of Cyclone III and computer(PC or labtop)" It's means that I must "ping IP and Relay from Cyclone's Ethernet". I don...
14 years agoOf course, That's I want to interface between on Board(Development kit) Cyclone III's Ethernet and a the other computer via Cable. And To solve this problem. I must have programmed to create a IP address and then from a computer(is connected with Ethernet via the cable). Then, I open the Terminal(DOS). typing "cmd" command and then "ping" IP_address(this address had programmed) and if the system rely ....... and display on the terminal is ok?????????????????????????
Thanks for your many helping:(
