14 years agoHOW TO INTERFACE BETWEEN ETHERNET(CYCLONE III) AND PCs(Labtop)
Hi everybody!!!
I'm studying with a topics "Interface between Ethernet of Cyclone III and computer(PC or labtop)" It's means that I must "ping IP and Relay from Cyclone's Ethernet". I don't know how to practice that i use Verilog language. it's difficult to me!!! Help me everybody53 Replies
Take Cyclone III Development kit or NEEK web server examples for starters.
i don't understand. Can you discrible your mind. I need to instruction detail about it. example .... I'm confuse... worried!!!!!
help me !!! anyone - Altera_Forum
What development kit do you have? Isn't it shipped with design examples?
Yes I do.
I'm doing on Development Board on Cyclone III. But I don't know how to set up IP for Cyclone III's Ethernet. My task is when I ping "Ethernet's IP address" it answer "Relay ...."comment ???????? that's all!!! - Altera_Forum
You need to upload the nios standard image (delivered with the kit) and compile and run a web server example..
Then the board will try to configure itself through dhcp so it can be a good idea to have a dhcp server on your PC if you don't want to configure the IP manually in the source code. - Altera_Forum
I can set up IP address for Cyclone III's Ethernet, and this is my code when I declare for this code.
/* * define_IP.h * * Created on: Dec 12, 2012 * Author: user01 */ # ifndef DEFINE_IP_H_ # define DEFINE_IP_H_ /* # pragma ident "@(#)ip.h 1.7 98/08/26 SMI" ip.h 1.13 88/08/19 SMI; from UCB 7.6.1.1 3/15/88 # include <sys/isa_defs.h> # ifdef __cplusplus extern "C" { # endif */ # define IPVERSION 4 /* * Structure of an internet header, naked of options. * * We declare ip_len and ip_off to be short, rather than ushort_t * pragmatically since otherwise unsigned comparisons can result * against negative integers quite easily, and fail in subtle ways. */ struct ip { # ifdef _BIT_FIELDS_LTOH uchar_t ip_hl:4, /* header length */ ip_v:4; /* version */ # else uchar_t ip_v:4, /* version */ ip_hl:4; /* header length */ # endif uchar_t ip_tos; /* type of service */ short ip_len; /* total length */ ushort_t ip_id; /* identification */ short ip_off; /* fragment offset field */ # define IP_DF 0x4000 /* dont fragment flag */ # define IP_MF 0x2000 /* more fragments flag */ uchar_t ip_ttl; /* time to live */ uchar_t ip_p; /* protocol */ ushort_t ip_sum; /* checksum */ struct in_addr ip_src, ip_dst; /* source and dest address */ }; # define IP_MAXPACKET 65535 /* maximum packet size */ /* * Definitions for IP type of service (ip_tos) */ # define IPTOS_LOWDELAY 0x10 # define IPTOS_THROUGHPUT 0x08 # define IPTOS_RELIABILITY 0x04 /* * Definitions for IP precedence (also in ip_tos) (hopefully unused) */ # define IPTOS_PREC_NETCONTROL 0xe0 # define IPTOS_PREC_INTERNETCONTROL 0xc0 # define IPTOS_PREC_CRITIC_ECP 0xa0 # define IPTOS_PREC_FLASHOVERRIDE 0x80 # define IPTOS_PREC_FLASH 0x60 # define IPTOS_PREC_IMMEDIATE 0x40 # define IPTOS_PREC_PRIORITY 0x20 # define IPTOS_PREC_ROUTINE 0x00 /* * Definitions for options. */ # define IPOPT_COPIED(o) ((o)&0x80) # define IPOPT_CLASS(o) ((o)&0x60) # define IPOPT_NUMBER(o) ((o)&0x1f) # define IPOPT_CONTROL 0x00 # define IPOPT_RESERVED1 0x20 # define IPOPT_DEBMEAS 0x40 # define IPOPT_RESERVED2 0x60 # define IPOPT_EOL 0 /* end of option list */ # define IPOPT_NOP 1 /* no operation */ # define IPOPT_RR 7 /* record packet route */ # define IPOPT_TS 68 /* timestamp */ # define IPOPT_SECURITY 130 /* provide s,c,h,tcc */ # define IPOPT_LSRR 131 /* loose source route */ # define IPOPT_SATID 136 /* satnet id */ # define IPOPT_SSRR 137 /* strict source route */ /* * Offsets to fields in options other than EOL and NOP. */ # define IPOPT_OPTVAL 0 /* option ID */ # define IPOPT_OLEN 1 /* option length */ # define IPOPT_OFFSET 2 /* offset within option */ # define IPOPT_MINOFF 4 /* min value of above */ /* * Time stamp option structure. */ struct ip_timestamp { uchar_t ipt_code; /* IPOPT_TS */ uchar_t ipt_len; /* size of structure (variable) */ uchar_t ipt_ptr; /* index of current entry */ # ifdef _BIT_FIELDS_LTOH uchar_t ipt_flg:4, /* flags, see below */ ipt_oflw:4; /* overflow counter */ # else uchar_t ipt_oflw:4, /* overflow counter */ ipt_flg:4; /* flags, see below */ # endif union ipt_timestamp { n_long ipt_time[1]; struct ipt_ta { struct in_addr ipt_addr; n_long ipt_time; } ipt_ta[1]; } ipt_timestamp; }; /* flag bits for ipt_flg */ # define IPOPT_TS_TSONLY 0 /* timestamps only */ # define IPOPT_TS_TSANDADDR 1 /* timestamps and addresses */ # define IPOPT_TS_PRESPEC 2 /* specified modules only */ /* bits for security (not byte swapped) */ # define IPOPT_SECUR_UNCLASS 0x0000 # define IPOPT_SECUR_CONFID 0xf135 # define IPOPT_SECUR_EFTO 0x789a # define IPOPT_SECUR_MMMM 0xbc4d # define IPOPT_SECUR_RESTR 0xaf13 # define IPOPT_SECUR_SECRET 0xd788 # define IPOPT_SECUR_TOPSECRET 0x6bc5 /* * Internet implementation parameters. */ # define MAXTTL 255 /* maximum time to live (seconds) */ # define IPFRAGTTL 60 /* time to live for frags, slowhz */ # define IPTTLDEC 1 /* subtracted when forwarding */ # define IP_MSS 576 /* default maximum segment size */ # ifdef __cplusplus } # endif # endif /* _NETINET_IP_H */ # endif /* DEFINE_IP_H_ */ */ - Altera_Forum
or i can set up other.
# define IP4_ADDR(ipaddr, a,b,c,d) ipaddr = htonl((((alt_u32)(a & 0xff) << 24) | ((alt_u32)(b & 0xff) << 16) | ((alt_u32)(c & 0xff) << 8) | (alt_u32)(d & 0xff))) mus i can do now? i'm confuse. - Altera_Forum
What does it say when you run the web server example?
In the project you should have a file with two functions that are called by the IP stack to set up the MAC and IP addresses. - Altera_Forum
okey.but i cannot...
i write a code for set up IP addresss. it cannot run. How must i declare for this code? that's : Ip address? example: i want to declare?????? i need a code for this. :confused::confused::(:( - Altera_Forum
What you posted are definitions, not code that actually set up the address.
What software project did you use? Have a look at the network_utilities.c file, there is a function called get_ip_addr(). The actual IP address to use is declared in a header file (web_server.h for the web server example).
