9 years agoHow to Interface 10M04SCU169 with Host processor
Hello All, I am new in this forum and FPGA device exp. I would like to know how we can interface MAX10 series FPGA to External MCU/ Processor How can we decide the IO lines at FPGA si...
9 years ago --- Quote Start --- You should know how large the intended FPGA register map is, if you possibly want additional dual port RAM. The decision rules the number of required address lines. The other parameter is data throughput. I already suggested a separate CS line for FPGA interface. A serial (SPI) interface would be a low pin count alternative for moderate data throughput. --- Quote End --- yes, we want to use DPRAM from the FPGA if the signal diagram is incorrect, pls advise what and where to correct in diagram.
