9 years agoHow to Interface 10M04SCU169 with Host processor
Hello All, I am new in this forum and FPGA device exp. I would like to know how we can interface MAX10 series FPGA to External MCU/ Processor How can we decide the IO lines at FPGA si...
9 years ago --- Quote Start --- Thanks a Lot Micro is RX631 169 BGA package from Renesas, Working on 3.3V VDD FPGA is also working on single supply 3.3V voltage RX631 is having 2 WAIT signal, 6 Chip Select, Write and Read signals and 24 address and 16 data lines
We have LAN9252 ESC interfaced to RX631 Micro by 4 address line and 15 Data Line So, please guide us about How to interface FPGA to Micro and LAN9252 to FPGA using address and data line i have attached pin mapping connection diagram
pls. revert back with suggestion and comments
--- Quote End --- Sorry, Micro is 100 LQFP package and FPGA is 169 BGA package Micro will read the DPRAM data (in FPGA ), its FPGA reads the timer pulses and stores the data in DPRAM register then micro will read it - we have one more interface with FPGA and MIcro and i,e LAN9252 i am confused about connection between micro, FPGA , should A0 address bit required in interface?
