9 years agoHow to Interface 10M04SCU169 with Host processor
Hello All, I am new in this forum and FPGA device exp. I would like to know how we can interface MAX10 series FPGA to External MCU/ Processor How can we decide the IO lines at FPGA si...
9 years ago --- Quote Start --- Micro is RX631 from Renesas make and 169 BGA package Could you please explain with example -that how to connect FPGA 10M01SCU to RX631 Micro pls share the other links also Do we required Wait signal for the interface? How many address and data requried ? --- Quote End --- From your description the uP has all 3.3V I/O, and so does your FPGA, so you can connect pins more or less as you desire. If your PCB is constrained you may want to choose an FPGA pinout that makes routing signals to your uP as simple as possible. As to how many address/data/select/wait lines to use, well it depends upon your application. You know that; I don't. Probably I would connect all of them, unless your FPGA is going to be I/O constrained for other signals. It is always easier to ignore or not use signals, but a lot more problematic if you need a signal that is not connected.
