9 years agoHow to Interface 10M04SCU169 with Host processor
Hello All, I am new in this forum and FPGA device exp. I would like to know how we can interface MAX10 series FPGA to External MCU/ Processor How can we decide the IO lines at FPGA si...
9 years ago --- Quote Start --- What micro are you using? How many I/O lines does it have for memory mapped peripherals? Yes - you will be able to connect the micro to any GPIO on the FPGA. There are no specific pins on the FPGA that you must use. Cheers, Alex --- Quote End --- Micro is RX631 from Renesas make and 169 BGA package Could you please explain with example -that how to connect FPGA 10M01SCU to RX631 Micro pls share the other links also Do we required Wait signal for the interface? How many address and data requried ?
