9 years agoHow to Interface 10M04SCU169 with Host processor
Hello All, I am new in this forum and FPGA device exp. I would like to know how we can interface MAX10 series FPGA to External MCU/ Processor How can we decide the IO lines at FPGA si...
9 years ago --- Quote Start --- Within limits, however. If the micro has 3.3V I/O, and the FPGA has multiple I/O banks, you must the I/Os populated in a compatible voltage bank. You may be using 1.8V or 2.5V I/O for some other interfaces, so those banks may not be compatible with a 3.3V I/O CPU interface requirement. So some planning will be necessary to choose where you connect the I/Os, but as indicated you will have a lot of flexibility of choice within an I/O bank. --- Quote End --- Thanks a Lot Micro is RX631 169 BGA package from Renesas, Working on 3.3V VDD FPGA is also working on single supply 3.3V voltage RX631 is having 2 WAIT signal, 6 Chip Select, Write and Read signals and 24 address and 16 data lines
We have LAN9252 ESC interfaced to RX631 Micro by 4 address line and 15 Data Line So, please guide us about How to interface FPGA to Micro and LAN9252 to FPGA using address and data line i have attached pin mapping connection diagram
pls. revert back with suggestion and comments
