12 years agoHow to increase number of words in RAM megafunction?
So I am using the dual port RAM mf, I noticed that the maximum number of words for any word size is 65536. Is there any way I can increase this? I want 3 bit words, and a lot of them. Will simu...
12 years agohow many is a lot? THe megafunction is limited to 16 bit addressing. If you have to use the megawizard/mf, then you will have to generate multiple rams (why not have 3x 1x64k ram in parrallel, 1 bit per ram ?)
Have you worked out exactly how many internal memory blocks your 3 bit word will need? Have you tried inferring the ram in HDL?
