17 years agohow to increase frequency
Hi, I have written a code in Verilog and its frequency is comming out to be 28MHz only for Cyclone EPC6Q240C8 device. The place where frequency drops is Average Calculation. I have 3 regi...
17 years ago --- Quote Start --- I don't see the design is completely pipelined. all statements involving three additions can be further pipelined e.g. --- Quote End --- Yes, that's true. I assumed however, that two 12-Bit additions in a cycle won't be an issue for 48 MHz. Average of 9 needs a divider or a approximation by integer multiply/shift. But with Cyclone, the integer multiply is converted to multiple additions and may cause timing problems as well. Alternatively, the divider can be pipelined, using a MegFunction. Cause dividers are resource consuming, I generally use a serial divider, where ever applicable. It e. g. takes 4 cycles for a /9 division.
