孝大村00
6 years agoHow to implement sspi command in uboot in Arria10 SoC Devkit
I am running Linux on Arria10 SoC Devkit. I refer to the link here to create uboot. And it is working fine. With Arria10 SoC Devkit, you can give instructions to the System Controller (MAX V) from ...
孝大村00
6 years agoHi.
I will share my environment.
Quartus : 18.1 std
U-Boot : 2019.04
Kernel : 5.4.13
As a supplement, KP occurs when the SPI Driver of Kernel is enabled.
When build a Kernel, set the SPI Driver to Disable.
I was fine because I didn't need to use SPI on Linux.
A countermeasure is required when using SPI on Linux.
Thank you.
best regards
