孝大村00
6 years agoHow to implement sspi command in uboot in Arria10 SoC Devkit
I am running Linux on Arria10 SoC Devkit. I refer to the link here to create uboot. And it is working fine. With Arria10 SoC Devkit, you can give instructions to the System Controller (MAX V) from ...
孝大村00
6 years agoI solved myself.
The problem was resetting "Per-Master Security bit for spi_master1: 0xFFD13020".
It was necessary to add "resets = <& rst SPIM1_RESET>;" to uboot DTS.
The changes are as follows.
[Configure uboot]
CONFIG_CMD_SPI=y
CONFIG_DEFAULT_SPI_BUS=0
CONFIG_DEFAULT_SPI_MODE=0
CONFIG_DESIGNWARE_SPI=y[Device Tree]
<< socfpga_arria10.dtsi >>
spi1: spi@ffda5000 {
compatible = "snps,dw-apb-ssi";
#address-cells = <1>;
#size-cells = <0>;
reg = <0xffda5000 0x100>;
interrupts = <0 102 4>;
num-chipselect = <4>;
bus-num = <0>;
/*32bit_access;*/
tx-dma-channel = <&pdma 16>;
rx-dma-channel = <&pdma 17>;
resets = <&rst SPIM1_RESET>; /* ADD */
clocks = <&spi_m_clk>;
status = "okay";
spidev@0 { /* ADD---> */
compatible = "rohm,dh2228fv";
reg = <0x0>;
spi-max-frequency = <100000>;
}; /* <---ADD */
};<< socfpga_arria10_socdk.dtsi >>
aliases {
ethernet0 = &gmac0;
serial0 = &uart1;
i2c0 = &i2c1;
spi0 = &spi1; /* ADD */
};However, while Read seems to work fine, Write does not seem to work properly.
>> sspi 0:0 16 02C0 --->LED control is not performed correctly.
>> sspi 0:0 16 0500 ---> The status of DipSW and Push Button can be read correctly.
Thanks!
