How to implement LFPS in Cyclone 10 GX transceiver IP
Hi Yt_aem,
I don't found any information that related to LFPS for transceiver itself but maybe you can try to modify the logic inside it.
zying
- Yt_aem2 years ago
How to change the logic inside the transceiver? do you mean at fabric side?
Transceiver includes PMA and PCS layers. We need 8b/10b encoder and decoder of PCS. The LFPS must happen at PMA layer. After PCS in transmitting channel we can't send out a 01010101... sequence signals to PMA. So, at fabric /logic side, it is impossible to design the LFPS signal to my understanding.
Since in your dev. kit board there is a USB3.1 circuit having been designed already, I bet, you guys should give out such kind of design guideline, don't you?
Looking forward to your helps. I am stuck there.
Appreciate a lot!
yaoting
