How to implement LFPS in Cyclone 10 GX transceiver IP
Hi Yt_aem,
"In USB3.0/3.1 it needs to send a side band signal, Low frequency Period Signal(LFPS) to other partners." Can you clarify more about this? May I know that it will send to which things?
zying
Hi Zying,
In USB3.0/3.1 protocol, when you plug in a USB C connector the first thing of first is that both source and device ends send out a low frequency clock signal about 10 MHz over the transmit line of the USB to let the partner know "I am connected" or to wake up each other then they go to training mode. See USB3.0/3.1 spec.
From your Intel Dev board for cyclone 10 GX there is a reference design for USB3.1 interface in circuitry. See sheet 24 of the schematic attached. I did not find any circuit to support this side band clock signal. That looks like it has to be generated from the cyclone 10 GX transceiver itself. If this is true, my question is, how to configure the transceiver by Quartus Prime software?
Yaoting
