MPETE26
7 years agoHow to get virtual UFM included into pof.map
v18.1 tools, Nios II/e device: 10M16DCU324 We're executing from flash. Summary.html shows larger onchip_flash_0 space. mem_init_generate or conversion to pof file: conversion.map file still show...
- 7 years ago
The issue was incorrect device on the HW: a 10M16DCU324 was installed while a 10M16DAU324 or 10M16DFU324 should have been installed. The 'DC' does not support virtual-UFM in the CFM sectors.
JohnT_Altera
7 years agoHi,
You will need to set your Quartus design to Single Uncompressed Image which will make the space available in On Chip Flash IP.
