12 years agoHow to get the Control Design In Quartus
Hello All
I am trying to design th 32 bit ALU with 5 function as given in this slide presentation http://www.cse.ohio-state.edu/~crawfis/cse675-02/slides/cse675_05_aludesign.pdf While Designing 1 Bit ALU I am stuck how to design the operation in Quartus Can anybody let me know what symbol is used in quartus for that1 Reply
I don't think there is a Quartus primitive that matches the ALU you're trying to create from the presentation. If you're planning to capture a Quartus schematic implementing this you'll have to use lower level primitives if you want to build the ALU as detailed in the presentation.
This would be very easy to implement in rtl (verilog or VHDL)...:)
