17 years agoHow to get rid of warnings?
Hi everybody, Is there any site or document which deals with warnings messages and how to get rid of them? I got such types of warnings *Info: Pin "y[0]" has no specified output p...
17 years ago --- Quote Start --- *Info: Pin "y[0]" has no specified output pin load capacitance -- assuming default load capacitance of 0 pF for timing analysis --- Quote End --- Goto Assignments > Device > Device and Pin Options > Capacitive Loading and fill out the table accordingly. --- Quote Start --- *The Reserve All Unused Pins setting has not been specified, and will default to 'As output driving ground'. --- Quote End --- This is in the same Device and Pin Options but under Unused Pins and Reserve all unused pins. ssd_7[0] must have some logic that sticks it high, is this desired behavior?
