17 years agohow to generate tone in DE1
hi, i come across this project in this site http://www.fpga4fun.com/musicbox.html, which creates a music box. I wan to implement them in DE1 board but i dun know how to use the audio parameters. ...
17 years agoI believe the line out is connected to the wolfson audio codec chip. You would have to communicate with that chip to initialize it, and then generate the tones. This is a little more complicated though - if you're interested take a look at the DE1 synthesizer demo for tone generated music, or at the DE1 audio demo for playing PCM.
Using a mif file is not required, it's just to have some kind of ROM behavior. You can use even a big case switch to specify the tones to play, like in the MusicBox tutorial.
