11 years agoHow to generate .hexout File for MAX10 Devices
Hi. On cyclone devices, it was easy to get a .hex file by using the "convert programming file" tool. Now, when i try to get a hexout out of a .sof file, it shows a message "Device 10M08SAE144ES does ...
11 years agook, thanks. the .rpd file was a good hint. In an741 (https://www.altera.com/en_us/pdfs/literature/an/an741.pdf) i found a work-around to extract the data i was looking for (i hope that is "all i need")
--- Quote Start --- 1. On the File menu, click Convert Programming Files. 2. Under Output programming file, select Programmer Object File (.pof) in the Programming filetype list. 3. In the Mode list, select Internal Configuration. 4. In the File name box, specify the file name for the programming file you want to create. 5. To generate a Memory Map File (.map), turn on Create Memory Map File (Auto generateoutput_file.map). The .map contains the address of the CFM and UFM with the ICB setting that youset through the Option/Boot Info option. 6. To generate a Raw Programming Data (.rpd), turn on Create config data RPD (Generateoutput_file_auto.rpd).With the help of Memory Map File, you can easily identify the data for each functional block inthe .rpd file. You can also extract the flash data for third party programming tools or update theconfiguration or user data through the Altera On-Chip Flash IP. --- Quote End --- The IP Catalog shows a Remote Upgrade IP Core. This one seems to be able to write to the CFM. The Problem is, there is a huge inconvenient Avalon Bus on it. In this document (https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/ug/ug_altremote.pdf), its talking about a direct ip core variant - but i cant find an option for direct access interface as shown on Page 9. :-(
