11 years agoHow to generate .hexout File for MAX10 Devices
Hi. On cyclone devices, it was easy to get a .hex file by using the "convert programming file" tool. Now, when i try to get a hexout out of a .sof file, it shows a message "Device 10M08SAE144ES does ...
11 years agoIt's interesting, but I see the same issue. But the question is why do you need a bootloader, when you program the internals once and it's done.
You will be able to write a converter from the SOF or POF file, but that's really a binary format. Pete
