11 years agoHow to generate clock in altera ep2c5t144c8 board?
Hi!
I am facing problem for generating clock in ep2c5t144c8 board of altera quartus II. I have tried many times to set the clk in time quest analyses but it is not giving any response when I check my desired signal on oscilloscope! I have attached the screen shots of 'create clock' and 'name finder' windows. everyones response will be highly appreciable! Thank you!
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
library STD;
use STD.TEXTIO.all;
--use ieee.std_logic_arith.all;
entity pwncheck is
port (
clk : in std_logic;
reset : in std_logic;
led : out std_logic);
end pwncheck;
architecture operation of pwncheck is
signal count_pwm_freq : unsigned(11 downto 0);
signal set_pwm_duty : unsigned(11 downto 0);
signal freq_pwm_maint : unsigned (11 downto 0);
begin
process(clk,reset)
begin
if (clk'event and clk = '1')then
count_pwm_freq <= count_pwm_freq + 1;
--"010011100010" ;--010011100010=>1250
if (count_pwm_freq = 010011100010)then
led <='0';
else if (count_pwm_freq = "100111000100")then --100111000100=>2500
count_pwm_freq <= (others => '0');
led <='1';
end if;
end if;
end if; --clock
end process;
end operation;
1 Reply
Change
toif (count_pwm_freq = 010011100010)then
Cheers, Alexif (count_pwm_freq = "010011100010")then
