16 years agoHow to generate a clock signal using combinational logic
For some reasons, my board doesn't feed a clock to the cpld, and i need a clock signal for some functions, so i want to using combinational logic to generate a clock signal. Can anyone give me some advices?!
BTW, i just need a rough clk signal, not accurate, such toggling signal is ok!!! Thanks a lot!3 Replies
If you're targeting to classical Altera CPLD as MAX3000 or MAX7000, you'll realize, that the synthesis attributes needed to keep logic cells for a ring oscillator most likely won't work, because they are apparently unsupported by the CPLD synthesis tools. They can work with MAX II, that uses FPGA synthesis tools.
Ok, I got it! It's very usefule for me!
Thank you very much! - Altera_Forum
Try taking a look at this
http://www.alteraforum.com/forum/showthread.php?t=709
