16 years agoHow to generate a clock signal using combinational logic
For some reasons, my board doesn't feed a clock to the cpld, and i need a clock signal for some functions, so i want to using combinational logic to generate a clock signal. Can anyone give me some a...
16 years agoIf you're targeting to classical Altera CPLD as MAX3000 or MAX7000, you'll realize, that the synthesis attributes needed to keep logic cells for a ring oscillator most likely won't work, because they are apparently unsupported by the CPLD synthesis tools. They can work with MAX II, that uses FPGA synthesis tools.
