SusanB
4 years agoHow to fix Power Estimation Confidence: Low: user provided insufficient toggle rate data
In my design, I have a 6b x 12b multiplier that is inferred from code that is essentially if(rising_edge(clock)) then
if (clock_enable = '1') then
result <= num_6b * num_12b;
end if...
Farabi_Altera
4 years agoHello,
The way to get power estimates with high confidence is to use the toggle rate that comes from simulation or user-entered assignments. Refer to the "Confidence Metric Details" section in the link below,
https://www.intel.com/content/www/us/en/programmable/documentation/osq1513989409475.html
That being said, the way to tell the Power Analyzer Tool to use toggle rate from the simulation is with a vcd file. Here is a small guide to generate a vcd file in ModelSim,
https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/solutions/rd07062010_692.html
regards,
Farabi
