9 years agoHow to find out a Tco from TimeQuest
Hi all! I'm using Quartus TQ and I have a question about the best way to measure a Tco for a FPGA pin to pin. My task is specifically for the case in that example - https://www.altera.com/conte...
9 years ago --- Quote Start --- I think you want the datasheet report. http://quartushelp.altera.com/15.0/mergedprojects/analyze/sta/sta_com_report_datasheet.htm --- Quote End --- Thank you very much, rbugalho. I will try your suggestion and write if it helps!
