9 years agoHow to feed rx_dataout back to tx_datain in Cyclone IV GX transceiver?
Hi, all: I'm using Cyclone IV GX (EP4CGX50CF23I7) to design some project with transceiver. As illustrated below, how to loop rx_dataout back to tx_datain? rx_dataout and rx_clkout is synchr...
9 years ago --- Quote Start --- You can add a FIFO between RX_DATAOUT and TX_DATAIN, where each of the input and output is sync'ed to the appropriate clock domain. The size of the FIFO depends on the maximum difference between input and output clock rates you need to compensate for. If new data arrives and the FIFO is full, you must drop a data word; likewise if you need to transmit data and the FIFO is empty to need to stuff a null word. Other than that the logic design should be reasonably straightforward. --- Quote End --- Hello Ak6dn, thank you for your response! I have already considered this solution. In this case, It means dropping some frames , which is not acceptable in this project. The transmitted data should be exactly the same as received data.
