10 years agoHow to estimate the effective bandwidth of cycloneiv ddr2 HPC II?
Hi all: I am preparing a cycloneiv+DDR2 based image solution. These is one question puzzles me. What is the effective bandwidth of DDR2 if I select altera's ddr2 HPCII ipcore? Th...
9 years agoHi
The project is almost complete. We are using 32bit DDR2 and set the DRR2 HCPII as 160Mhz DDR2 clock output. The input stream is 24bit x 148Mhz and same bandwidth as output stream. So these is 8 bits watse on DDR2 side. Then we covert the 24bit RGB to YUV422 as simple compression. We use a 16bit to 32 bits FIFO as cross clock domian FIFO to make the best of DRR2's 32bits. Then it works. Is these any solution can make the best of DRR2' s 32bits with 24bits RGB raw input?
