9 years agoHow to enable USB with Linux 4.11 and DE2-115
I can boot Linux 4.11 with Altera DE2-115. I want to enable USB. How can I know where the problem is? I added a USB in QSys but I can't verify that it actually works. I also added USB in menuc...
9 years ago --- Quote Start --- Hello, Your Qsys image is not clear. Could you send another image? If you don't mind, can you let me know use of USB in your application. Regards, Bhaumik --- Quote End --- I use Linux 4.11 from altera-opensource in github. Linux 4.11 starts and I want to just make the USB work and use persistent storage with the operating system. I also tried SD card but that did not work either. The Qsys design compiles cleanly and the programmer loads the system and Linux 4.11 starts cleanly but there is not working USB. I thought that I could just run lusb and the usb would appear. What am I supposed do to? You may find a clear image of my Qsys from this link http://i.imgur.com/52enb9b.png https://alteraforum.com/forum/attachment.php?attachmentid=13557&stc=1 https://alteraforum.com/forum/attachment.php?attachmentid=13558&stc=1
