10 years ago
How to enable SDRAM ECC in the Qsys
How can I enable SDRAM ECC in the Qsys?
Best Regards
    It looks like DE0-Nano-SoC only has 32 DQ pins - thus I think you can't use interface width of 40. You can try using 24 and see if it is working.
    I select interface width 40. Should I use interface width 24 for DE0-Nano-SOC board?
    Many thanks. Can I used this way for DE0-Nano-SOC board?
    Best Regards
    I assume you are talking about the HPS SDRAM (which is different from the FPGA SDRAM). For HPS SDRAM, navigate to the HPS Qsys Component --> SDRAM tab --> Memory Parameters
    If you are using 32-bit interface width, put the number "40" here. In the Qsys Message box, you should see the note:
    Info: soc_system.hps_0: ECC will be enabled in the preloader because an interface width of 24 or 40 has been chosen.
