10 years agoHow to enable SDRAM ECC in the Qsys
Hi, How can I enable SDRAM ECC in the Qsys? Best Regards
10 years agoI assume you are talking about the HPS SDRAM (which is different from the FPGA SDRAM). For HPS SDRAM, navigate to the HPS Qsys Component --> SDRAM tab --> Memory Parameters
If you are using 32-bit interface width, put the number "40" here. In the Qsys Message box, you should see the note: Info: soc_system.hps_0: ECC will be enabled in the preloader because an interface width of 24 or 40 has been chosen.
