16 years agohow to download u-boot to the NEEK
Hi any! !
Could you please tell me why U-boot does not work on NEEK? When I downloaded following file and compile it(nios2-linux-20090929.tar),I got the following error message. We excuted NIOSⅡ 9.0 Command Shell on Windows with following procedures. Connecting NEEK and PC via USB cable bundled NEEK. Step1) u-boot compile. linux$ cd nios-linux/u-boot linux$ make clean linux$ make NEEK_C3_config linux$ make Step2) sof-file donwload. (Using the neek_ocm_spi_mmu.zip "sof-file".) [NiosII EDS]$ nios2-configure-sof cycloneIII_embedded_evaluation_kit_standard.sof Step3) u-boot donwload. [NiosII EDS]$ nios2-download -g u-boot Step4) Execute. [NiosII EDS]$ nios2-terminal.exe The error message is follows. > [NiosII EDS]$ nios2-download -g u-boot > Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 > Pausing target processor: not responding. > Resetting and trying again: OK > Initializing CPU cache (if present) > OK > Downloaded 98KB in 0.5s (196.0KB/s) > Verified OK > Starting processor at address 0x01FC0000 > assertion "m_state == STATE_DEBUG" failed: file "nios2debug.cpp", line 538 > 4 [sig] nios2-gdb-server 584 c:\altera\90\nios2eds\bin\nios2-gdb-server.ex > e: *** fatal error - called with threadlist_ix -1 > /cygdrive/c/altera/90/nios2eds/bin/nios2-download: line 594: 584 Hangup > nios2-gdb-server --go --tcpport none --write-pid ./nios2-download.pid > ./u-boot.srec The combination of following U-boot and the neek_ocm_spi_mmu.zip "CycloneIII_embedded_evaluation_kit_standard.sof" worked correctly. (nioswiki.com, Extrem_guide_to_kill_NEEK_with_u-boot) I tried to fix it refer to above error message, but I couldn't . Could you please tell me I'm getting this error? Can you tell me how can I fix it?No RepliesBe the first to reply
