13 years agoHow to do the timing constraint?
Hi, Refer to the appendix,how to do the timing constraint with the both FPGA to reach the expected timing? for the set_input_delay and the set_output_delay,what time relation does it tell ...
13 years ago --- Quote Start --- What effect were you hoping for? As far as I can see, all the signals there have good setup/hold margins and you should not be getting any violations in post-fit simulation. --- Quote End --- The timing was OK,But the clock dindn't capture the data at the middle position of the data. And I hope it does.Do you have any way to do that?
