13 years agoHow to do the timing constraint?
Hi, Refer to the appendix,how to do the timing constraint with the both FPGA to reach the expected timing? for the set_input_delay and the set_output_delay,what time relation does it tell ...
13 years agoThe detail of the test mentioned above.
FPGA1 : registers to Outputs(Setup) https://www.alteraforum.com/forum/attachment.php?attachmentid=6642 FPGA1 : registers to Outputs(Hold) https://www.alteraforum.com/forum/attachment.php?attachmentid=6643 FPGA2 : Inputs to registers(Setup) https://www.alteraforum.com/forum/attachment.php?attachmentid=6644 FPGA2 : Inputs to registers(Hold) https://www.alteraforum.com/forum/attachment.php?attachmentid=6645 post-sim with connecting the both FPGA in series https://www.alteraforum.com/forum/attachment.php?attachmentid=6647 the test's timing didn't reach the best effect. At this case,the slack of setup had 5ns to 7ns.Wasn't it enough? How to judge whether the timing has reached the best effect by the slack value?
