13 years agoHow to do the timing constraint?
Hi, Refer to the appendix,how to do the timing constraint with the both FPGA to reach the expected timing? for the set_input_delay and the set_output_delay,what time relation does it tell ...
13 years agoFirst, that ODDR module on fp1_co is not needed.
Second, you should also use a PLL on FPGA2 if possible. You need to set I/O constrains on the two FPGAs as normal. In the case of FPGA1, this means creating a derived clock on the fp1_co port and setting the output delays referenced on that clock. In the case of FPGA2, you create a base clock on fp2_ci and set the input delays referenced to that clock. The trick is that you need to keep the following relationship: fp1_max_output_delay + fp2_max_input_delay = clock period fp1_min_output_delay + fp2_min_input_delay = 0 This will be an iterative process. I'd start by with fp1_max_output_delay = fp2_max_output_delay = clock_period/2 and fp1_min_output_delay = fp2_min_input_delay = 0 and see what I get and then adjust as needed.
