16 years agohow to do pin assignment with Ethernet IP
HI,everybody. I am wondering how to do pin assignment with my board , cycone II, using magawizard ethernet IP. I watched the input and output signals after completing the ip core ,so many sign...
16 years agoIt won't work. The TSE IP can't be interfaced with the LAN91C111 chip.
If you are using SOPC builder there is a component for the LAN chip that you must use instead of the TSE IP.
