16 years agohow to do pin assignment with Ethernet IP
HI,everybody. I am wondering how to do pin assignment with my board , cycone II, using magawizard ethernet IP. I watched the input and output signals after completing the ip core ,so many sign...
16 years ago --- Quote Start --- Are you sure you used the correct IP for the correct chip? What Ethernet chip do you have on the board and which IP did you use? --- Quote End --- i am not sure, iam the beginner to use Ethernet IP core. The chip in the Cyclone ii EP2C35 belongs to SMSC(MAC+PHY) which only support 10/100BASE. following is the attachment. thanks.
