TY-Three
5 years agoHow to determine the pins of seriallite protocol used in arria II GX devices
CheepinC_altera
5 years agoHi,
As I understand it, you have some inquiries related to the SerialLite protocol used in Arria II GX devices. I believe you are referring to the SerialLite II IP. Would you mind to further elaborate on your inquiries ie if you encounter any problem fitting the IP in the device?
If you do not have pre-defined pin placement yet, you can let Fitter perform the auto-placement of the pins according to your design. Fitter will help to check against all the internal placement rules to ensure optimal placement.
- TY-Three5 years ago
Hello!
Thank you very much.
Your reply helped me a lot.
If I encounter problems again, I will seek your help as soon as possible.
Once again, my sincere thanks.
