17 years agoHow to determine the length of the RBF file
Hi, When we generate the RBF file from the .sof file with compression enabled using the convert programming files option in Quartus II , is the length of the RBF file embedded into the file...
16 years agoThe length of the file is found within the file but it's encoded. The best place I can point you too is the assembly source code for the NIOS II bootloader found in "c:\altera\90\nios2eds\components\altera_nios2\boot_loader_sources\boot_loader_epcs_bits_sii_siii_ciii.S":
// If we arrive at this point we have verified that there is valid-looking
// configuration data. Extract its length.
// Like searching for the Software-Device ID code, the configuration
// bitstream length is encoded in a particular bit of a run of bytes.
// Total length field is 32 bits, which goes from CB Option bits 86..55
// corresponding to bit of byte to byte (for the most
// significant 7 bits) followed by the range of bits
// made up of bit of bytes. The above note about EPCS
// bit reversal still applies (so we're really looking at bits and ,
// respectively.
// Jake
