16 years agoHow to Design a Multiplier Circuit using AHDL?
Hi all: I have a multiplier circuit built using Multisim and I suppoosed to use AHDL to implement the circuit. Problem is, I don't know where to begin and how to actually use the circuit. Here ar...
16 years agoThe device family is the chip you chose. And which chip you chose really depends on application.
If you want millions of gates and high-speed coms, you got for a stratix 4 ($thousands), if you need something cheap that can still do plenty you go for a cyclone 3 ($hundreds). With modern devices as they all have plenty of memory and embedded multipliers, there are only 2 main deciding factors 1. Cost 2. Comms required I get the feeling the question is aimed at much more outdated technology though.
