12 years agoHow to delay clock in real hardware?
Hello all, I have PWMs (4) signals and I want to delay the second signal to go high when the first signal goes from high to low in real hardware. I have 4 phases DC-DC buck converter to power ...
12 years ago --- Quote Start --- Hello all, I have PWMs (4) signals and I want to delay the second signal to go high when the first signal goes from high to low in real hardware. I have 4 phases DC-DC buck converter to power 8K Watt. How do I delay the clock in second, third, and fourth signals? I'm be able to shift the phases out equally. Thanks, Sean --- Quote End --- Why delay clock? if you are just after those patterns then have a fast enough clock and generate those patterns on same one clock.
