9 years agohow to declare 2D array in package and the same i want to use
HOW TO DECLARE 2-D ARRAY FOR MEMORY IN PACKAGE.
THE SAME VARIABLE I WANT TO USE IN OTHER PLACE WHERE I AM CALLING THAT PACKAGE. library ieee; use ieee.std_logic_1164.all; package constant_package is constant DATA_WIDTH : integer; constant ADDR_WIDTH : integer; subtype word_t is std_logic_vector ((DATA_WIDTH-1) downto 0); type memory_t is array (2**ADDR_WIDTH-1 downto 0) of word_t; end constant_package; package body constant_package is constant DATA_WIDTH : integer := 8; constant ADDR_WIDTH : integer:=8; end constant_package; THIS IS WHAT MY CODE IS IT OKK???1 Reply
It is ok. You can declare your type as follows for more simplicity.
type memory_t is array (2**ADDR_WIDTH-1 downto 0) of td_logic_vector ((DATA_WIDTH-1) downto 0); use your package in other files. You can even define port types as memory_t (Beauty of VHDL)!
