11 years agoHow to create sine and cos waves of different frequencies using Cyclone III(VHDL)
Hi, Is there anyone can help me to deal with one problem: How to create sine or cos waves in Cyclone III FPGA in VHDL. I have no clear idea to program the VHDL code although I have search some ...
11 years agoHi Tricky,
I have learnt VHDL and I suppose I have some knowledge of this language. But just for this application, I have not clear idea to achieve this. In my mind, I want to use Look up table, due to the ADA board is 14 bits, and I have generated the different values in Excel for one cycle, I am not sure should I generate all 2^14 values or not. Thanks for your reply. Best wishes, peipei --- Quote Start --- If you have no VHDL knowledge, my first suggestion would be to find a good tutorial and get yourself familiar with the language. As for the sin waves, sine and cosine are identical, but with a phase shift. It would be easy enough to build a ROM of sin values in VHDL and just read them out. --- Quote End ---
