Artak
4 years agoHow to create IP from a multy-library vhdl project in Quartus.
I have a Quartus vhdl project consisting of about 10 vhdl libraries and about 150 vhdl files.
Would like to create an IP from it in order to instantiate to a bigger design.
The same project for x...
- 4 years ago
Since you're using Pro, probably the best solution would be to use the core reuse developer flow to create a .qdb file. Documentation here: https://www.intel.com/content/www/us/en/docs/programmable/683247/19-4/block-based-design-flows.html. Training here: https://cdrdv2.intel.com/v1/dl/getContent/652869?explicitVersion=true.
Nurina
4 years agoHello,
Does the above reply answer your question?
Nurina
