12 years agoHow to craete a 1 microsecond interval Timer of HPS ?
What HWLIB APIs should I use to configure a Timer of HPS with a 1 micro-second interval ? How can I get the Timer Input Clock frequency and set the appropriate count into Timer ? Than...
12 years agoThanks.
I have modify the example project , to set a Timer with 20KHz / 80KHz ( 12.5us period), in Timer ISR, I will toggle the LED in FPGA side . So that I can measure the time with SignalTap-II. OSC1_TMR0, 20KHz / 80KHz is fine, almost approached. But when I send OSC1_TMR0 timer with 1 MHz, the result is slower than I expected. Why ? ( It should have 1us interval, but I measured 6.5us...) [20KHz] https://www.alteraforum.com/forum/attachment.php?attachmentid=9194 [80KHz] https://www.alteraforum.com/forum/attachment.php?attachmentid=9195 [1M Hz] https://www.alteraforum.com/forum/attachment.php?attachmentid=9193
