9 years agoHow to control the DATA input of a LUT
Hi all, i am using lut_input/lut_output primitives to define a LUT function, and i want to control which DATAx input of LUT is used. For example, i want to use DATAC input of LUT, but it seem...
9 years agoI originally think that the inputs of a LUT share all local interconnect lines, that each input mux before DATAx could connect DATAx to any of local interconnect lines.
so i think when i simply change from DATAD to DATAC, it should be easy for QII to achieve fitting. It seems in fact that the input mux does not connect all local interconnect lines, so a local connect line may be connected to DATAD input mux, but not connected to DATAC input mux, that DATAD and DATAC are not exchangable in this situation. so i need to use wildcards in routing channel to ease QII fitting, then my purpose will be reached(that is, i could change from DATAD to DATAC freely). --- Quote Start --- I don't have an answer for you, but I'm curious as to why you want or need to do this. --- Quote End --- Well, it is an interesting thing for me, may be i will not use this technique forever, but it may help me think other problems. Thanks much for your attention. Best Wishes, ingdxdy
