14 years agoHow to connect two FPGA board?
Hi all; Is there any document on this subject?
14 years agoYou can probably use the 40-pin expansion headers and put wires between the two boards. Have a look at the board schematics to check what pins you can use.
As for accessing the memory blocs, then you'll probably have to design your own protocol.
