11 years agoHow to connect an FPGA input port to QSYS pio inout port
Hi, I have a QSYS/NIOS system, exporting bidirectional PIO port. Now I'd like to connect input port of top level to the bidir PIO port, with no success so far. I have tried with an helpe...
11 years agoHi,
Sure, that is the way to do it if stripping of the inout functionality doesn't work. But std_logic type is designed to be resolved. The problem might be that Altera (as a U.S. company) is putting all efforts to verilog, and supports vhdl only because they have to -with a minimum effort. I don't speak verilog, so don't know if there is similar functionality available. At least the following code works in simulator (the behaviour of port 2) as intended. The synthesis tool has all the information needed to make the internal unidirectional (no tri-state buffers) netlist work with equivalent behaviour. BR, -Topilibrary ieee;
use ieee.std_logic_1164.all;
entity gpio is
port(
gio_inout: inout std_logic_vector(3 downto 1)
end;
architecture test of gpio is
begin
process
begin
gio_inout <= "000";
wait for 1 ms;
gio_inout <= "111";
wait for 1 ms;
gio_inout <= "ZZZ";
wait for 1 ms;
end process;
end;
library ieee;
use ieee.numeric_std.all;
entity top is
port(
p1_inout: inout std_logic;
p2_in: in std_logic;
p3_out: out std_logic
end;
architecture test of top is
signal p2: std_logic;
begin
gp: entity work.gpio
port map(
gio_inout(1) => p1_inout,
gio_inout(2) => p2,
gio_inout(3) => p3_out
p2 <= 'H' when to_01(p2_in) = '1' else 'L';
end;
library ieee;
entity tb is
end;
architecture test of tb is
signal p1: std_logic;
signal p3: std_logic;
begin
t: entity work.top
port map(
p1_inout => p1,
p2_in => p2,
p3_out => p3
process
begin
p1 <= '0';
p2 <= '0';
wait for 3 ms;
p1 <= '1';
p2 <= '1';
wait for 3 ms;
p1 <= 'Z';
p2 <= 'Z';
wait for 3 ms;
end process;
end;
