How to configure SDRAM for HPS ?
- 7 years ago
Timing constraints for most IP, including memory interfaces, are set up automatically when you generate the IP. You still need to provide constraints for clocks that drive your FPGA logic, but constraints for the IP itself are handled for you.
Important side note: the tool is no longer called Qsys. It is now called Platform Designer. It still uses .qsys files, but you won't find the tool if you're looking for Qsys.
#iwork4intel
#iwork4intel
