9 years agoHow to configure sampling instant in MAX10 ADC ?
Hi everyone, I'm currently working on my end of degree project at university which is about using a MAX10 FPGA for Closed-loop Control Systems. The thing is that in order to make it work, I ...
9 years agoYou can either filter all the sampled data to what you want or if you've enabled the slave interface on the core, simply tell it to stop running when you don't want it to. Run/stop is bit 0 in the command register, address offset 0x0.
