12 years agoHow to configure DDR3 and calculate parameters of DDR3 controller with uniphy?
Hi everyone! I'm implementing a nios2 system to use DDR3 on tratix V DSP Development Kit using Qsys. But I don't know how to configure DDR3 controller with uniphy, caculate board setting parameter...
12 years ago --- Quote Start --- There will be a model, for the DDR3 part used on that development board, listed in the 'Presets' panel on the right hand side of the UniPHY settings window. Select the part used from that list and it will populate all the fields for you. The part used on the development board will be listed in the user guide that came with the board. --- Quote End --- thank your answer, but tratix V DSP Development Kit use MT41J128M16HA-125 DDR3 and MT41J128M8JP-125 DDR3 of Micron, they are not in list the "Presets", so I think I will configure and caculate board setting parameters include setup and hold derating, board skew. But I don't know how to do it now?
