15 years agoHow to config GX transceiver as DisplayPort PHY receiver?
Hi~ There isn't any DisplayPort item in MegaWizard . How to config GX transceiver as DisplayPort PHY receiver?
14 years agoYou can implement Display Port using the ALTGX MegaWizard Plug-In Manager =>
- Select 'ALTGX' and the 'Basic functional mode' within the ALTGX MegaWizard.
- Select 'Receiver Only' as the operation mode. Specify the number of channels, data rate, input clock frequency as per your system requirements.
